Cresting machine
A place to show your work. Building quivers, arrows, trade points, possibles bags, powder horns, hunting gear, period clothing, turkey calls, knives, flemish strings, armguards, bullet boards, forged or cast hardware, furniture, hats, etc.
Cresting machine
Postby Backwoods » Mon Mar 15, 2010 10:14 pm
I spent the last two or three nights building a new cresting machine. I purchased a sewing machine motor several years back and just threw a crester together. I decided that if I had any hope of doing the work in the house, that I would have to spruce it up a bit.
I had a bracket fabbed at work. Sorry, forgot to focus first.
Add a little paint and a motor.
Then paint the dimmer switch box and cover. I bought a blank cover and drilled the hole for the dimmer shaft. If you will notice, this coordinates nicely with the cut off saw I built about 8 years ago.
I had a scrap piece of oak to use.
And I mounted and wired all the hardware to it.
But I didn't like the way things were working out. The board was shorter than I wanted and I was going to have to cut up a nice 1 X 8 to make all the supporting parts so I just changed gears.
I found a nice piece of cedar that I thought would make a better base. Here it is after ripping it, sanding it and adding a rib to it. It's still a little wet from wiping off the excess glue
Then I had to build me a little slide for the shaft to ride on.
And by the time I did all my whacking and then adding some clear water based poly it looked like this.
Some more clear coat on the base and a little Velcro in the "V" of the slide and I ended up with this.
Now it's time to throw the rest together.
I guess next I'll have to post a new set of freshly crested woodies :D
64" Red Fox Longbow
53# @ 28"
.54 Cal. Lyman Trade rifle.
Backwoods
Re: Cresting machine
Postby Greywolf » Tue Mar 16, 2010 1:31 am
What did you use on the motor shaft so it holds the arrow shaft? Surgical tubing?
Postby Backwoods » Tue Mar 16, 2010 8:57 am
Yea, I had a wrist rocket that the tubing was too unsafe to shoot. So i robbed it.
64" Red Fox Longbow
53# @ 28"
Backwoods
Postby TradRag » Tue Mar 16, 2010 9:06 am
That is sweet! I am still trying to finesse the Bohning Pro Crestor and hope to have a SpinRite soon. Love what you did. Looks awesome.
Postby Greywolf » Thu Feb 02, 2012 1:45 pm
Any pictures yet?
Ya didn't think we'd forget did ya? Hmmmmmmm ?
Postby CallMaker » Mon Feb 20, 2012 9:49 pm
Nice work on that crester.
Ed Blankinship
Physically Challenged Bowhunters of America
http://www.pcba-inc.org/
CallMaker
Postby Nitzi » Tue Aug 18, 2015 8:59 am
Hi guys.
I write to you from Romania. i specially made an account here to kindly ask mister Backwoods if he can show me what did he installed in that box and use his own words for this frase :Then paint the dimmer switch box and cover. I bought a blank cover and drilled the hole for the dimmer shaft. whats a dimmer shaft and what did he installed in that box ???
I bought a sweing motor exactly like in the pictures after i saw his post...how its time to install it . here the picture where i bought it : http://olx.ro/oferta/motor-masina-de-cusut-ID1OMCX.html
what can i do now to make it like yours ?? can you send me some close in pictures and PLEASE tell me what did you bought extra for this machine ( i mean electric parts ) . My father worked in electricity but pls explain with your won words what did u do QUOTE "And I mounted and wired all the hardware to it." we must know what to buy and how the install the motor on that piece of wood.
and what did u used to putt on that shaft to hold the arrow..can you send me a close in picture ??? u said " wrist rocket that the tubing was too unsafe to shoot" ....where can i get some of that ? show me a picture to get the hole picture :) if u get what i mean.... i LOOK FORWARD to hear from you
Nitzi
Postby Nitzi » Tue Aug 18, 2015 9:06 am
If anyone can help me with information and i will be more than happy ..i am very eager to make this machine and start cresting my own arrows. THANK YOU ALL IN ADVANCE
Nitzi
Postby McClura » Tue Aug 18, 2015 1:51 pm
Very nice Backwoods! :applaud:
I think I will make a sliding rest for my shaft crester and place a small rail on mine. The rest I have keeps moving left or right and the shafts are not running true.
I really like the set up. What did you use to attach your shafts to the motor shaft when cresting?
Wow, what a huge pile of lead. Round Balls or maybe 45-70 bullets??????
Very good photos also.
Mike
Oklahoma Selbow Society Charter Member
Member at Large-Oklahoma Selfbow Society
Member-Kansas Bowhunting Association
Life Member-National Muzzleloading Rifle Association
You don't quit playing when you get old, you get old when you quit playing!
McClura
Postby Backwoods » Wed Aug 19, 2015 11:51 pm
McClura wrote:Very nice Backwoods! :applaud:
Mike
I used surgical tubing. It's OK but I plan on making an aluminum adapter with a rubber insert. Maybe rubber hose or an O-ring inside.
LOL... It's about 150 lbs. of lead I harvested from a plumber friend. I plan on casting conicals for my 1:48 twist Trade Rifle.
64" Red Fox Longbow
53# @ 28"
Backwoods
Postby Nitzi » Sun Aug 23, 2015 5:15 pm
I assembled the machine. Tomorrow i post photos. i must look tomorrow for the surgical tubing or maybe the aluminium adapter with a rubber insert. keep u posted. till then here's one photo
[img]http://postimg.org/image/85i34edoh/[/img]
Nitzi
Postby Nitzi » Tue Aug 25, 2015 5:10 am
Sorry for posting in other language but i finally assembled the thing :)
The motor attached to the dimmer switch (that's for light bolts) then i putt a hose in the motor shaft to hold tight the nock of the arrow and i will attach 2 rollers for the arrow to spin on them to the board...i posted it because i am very proud of it. THANK YOU SO MUCH BACKWOODS. I send you a cold beer !!!!
https://vid.me/6KMm
Nitzi
Postby Backwoods » Fri Aug 28, 2015 11:02 pm
Great job!! :applaud:
64" Red Fox Longbow
53# @ 28"
Backwoods
Return to Craftsmanship and Smithing
