Super glue finish
Super glue finish
Postby rancid crabtree » Sun Feb 08, 2009 4:25 pm
After receiving lots of questions on how to do a super glue finish on a knife handle I decided to show the steps. This is not to say that this is the only and proper way to use super glue as a finish. It's just the way I do it. Super glue is used on tropical woods that have oils that prevent most finishes from drying, curing or hardening. It can be used on any wood.
First of all, This is for small projects since it is not really cost effective for large projects. At the same time, there are those that use a super glue finish on pool cues, pens, bowls, chess pieces and a host of other projects.
I went out and bought a 4 pack of .07 Oz. tubes for $1.99. I bought the regular and not the gel but have heard of people using the gel with good results.
Always read the warnings and understand the risks. I have chosen to ignore rule number four. I found rule number five a bit odd. I do want good results but I fail to see why it matters how me and the missus spend our free time or if we are good at it.
This glue is stinky but larger containers that are more expensive can be bought in a low odor version.
I used a scrap piece of Bubinga right off the saw. I did not sand it at all. I did this to show that super glue is gap filling and fills in the pores of the wood. I poured a small drop on the wood.
I spread it around with this brush. This is one of a set of ten brushes in various sizes that I got from my parents on my birthday. I've had them for 44 years. The two biggest ones don't work well and the two smallest ones are really only good for cleaning your ears. :D
I just spread it out until the piece is covered and never stop moving. It stays liquid for a short while.
And then hardens with a little less gloss. You can see the rough saw lines on the wood. but after I build up of a few coats, it will smooth over the bumps. *** DO NOT blow on it to dry it faster.
After two coats, I use 400 grit sandpaper to smooth out the brush marks and then wipe it with a clean cloth to remove the white dust.
On the back side of the piece I applied the same number of coats except on the last one, I blew on it to dry it faster and you can see the results. The water vapor in your breath makes the glue cloudy or foggy and you cant un-do the damage. You will have to sand it all off and start over. The same goes for touching the wet glue with your finger. The moisture in your skin will also turn the glue white.
After a few coats, you also get a build up on the tip of your brush.
Nail polish remover (Acetone) will remove the hardened glue. I wet a paper towel and set my finger in it.
I will also use some of that same 400 grit to clean of any glue left behind. Now the brush is clean.
Once hardened, I use 400 grit and 0000 steel wool to smooth the finish.
Super glue leaves a hard, crystal clear and water proof protective coating of acrylic plastic on the wood.
It can be buffed to a high sheen.
Give it a try the next time you are working on a small wood project or if making fishing jig heads or turkey calls or pistol grips, etc. Work outside or in an area with good ventilation.
Re: Super glue finish
Postby BowHuntingFool » Sun Feb 08, 2009 7:23 pm
Pretty cool, I never knew!
>>>---Joe---->
WhisperStik VoodooStik 58", 50#
Montana Longbow 64", 50#
Mohawk Longbow 64", 52#
Lyman .54 Deerstalker Flintlock
Lyman .50 GPR Flintlock
NRA Member
BowHuntingFool
Postby TradRag » Sun Feb 08, 2009 9:44 pm
That is amazing! I'd be the guy walking around with a lam glued to my hand. :o
Postby Lance Coleman » Sun Feb 08, 2009 10:45 pm
Thats awesome. I got two lil projects coming up I'm gonna try that on.
It's not what you do............ It's how you do it.
Lance Coleman
Postby Voodoo » Mon Feb 09, 2009 9:34 am
I use CA(superglue) to seal the wood pores on everything I make from knives to my Elk longbows, there is a difference in glue. I use the industrial types, Jet medium mostly, as it doesn't turn white(I use my fingers) and a 4oz. bottle can be had for $15.. and it lasts a long time....I also put a finish over it, Helmsman spar urethane, it works great!.
Freedom!, It's the best thing in life!, DRH 9/25/81-4/25/05
Voodoo
Postby Buddy Bell » Mon Feb 09, 2009 10:56 pm
This is very cool. I never knew. Thanks
Trad is 75% mental & 25% mental ))))====> Buddy Bell
Buddy Bell
Postby heavybows » Tue Feb 10, 2009 4:34 am
Yes i used it to coat my flight arrows. Marlon ;)
heavybows
Postby trapperDave » Wed Feb 11, 2009 12:02 pm
about how many coats do you use, how long between coats and how long till final product is cured?
Join us on my Facebook group...
Indiana hunting, fishing and trapping
trapperDave
Postby Double Tee » Sun Feb 15, 2009 11:41 pm
That is neat!!!----I have messed with that stuff for years building RC aircraft and have never thought of using it to finish wood.I have a knife I built a few years back,think I'll try that on the handle!Thanks for the build along.
John Quillin
Double Tee
Postby Pluck Yew » Mon Feb 16, 2009 12:00 am
Hey, good to know! thanks for the lesson! :o
Shawn....
(wanna be bowyer)
GIVE 'EM THE BIRD!
http://edinburgharrow.com/main.sc
Pluck Yew
Postby KsBow » Sun Mar 01, 2009 11:38 am
Excellent info. For Bigger projects, like a bow or gun stock, try a Massey finish. That is, take a tube of 5 minute epoxy, shoot both part of the epoxy into a pint jar and add some acetone. Ratio is about 4 to 1, acetone to epoxy. Put the lid on the jar and swirl it around until the epoxy is dissolved. Then use a small, soft, lintless piece of cloth to wipe on the finish. The acetone evaporates leaving behind a finish of epoxy. It dries fast and I put on two or three coats. I generally use some fine steel wool after the second coat. It leaves a fairly high gloss finish. I then, give the last coat a bit of steel wool and complete the job by laying on a coat of Johnson's Paste Wax. You'll have a durable, waterproof finish on your project. :D
Postby woodsman1031 » Mon Mar 02, 2009 2:00 pm
Has anyone ever tried super glue gel for the super glue finish?
JESUS SAVES!!!!
woodsman1031
Postby crooketarrow » Tue Mar 03, 2009 2:53 pm
I've been building selfbows for 20 years.Last year I built a bow out of Osage for a gentlemen.After staining it the color he wanted I always seal by bows with wax and a hair dryed totally water proofs it.Firer your hair dryer up every now and again or when ever you want a new looking bow.It dose make your bow look like it was just finished and get rid of those hunting scratchs.
He did'nt want to be bother with it.No problem I'd go to my old back up plan.I've used varafane spray leaves a thin plastic coating over your bow.No sweat I'll just go to LOWES and get a can.Well he wanted to shot his bow NOW.
He saw a tube of super glue laying on a shelf.and said it dos'nt matter You can even seal it with that super glue .I must have had a stupid look on my face.Because he said you build bows and never used super glue to seal a bow.What kind if a bow builder are you.I still must have had that look because he was still loking at me. It took me a second to come around.
Since then I've talked a friend into trying it on a bow he'd just finished.As far as I know it works great.He said thats what he's useing from here on.YOU NEVER TO OLD ARE YOU
If anyone else use's it PM me. :mrgreen:
crooketarrow
Postby RickBarbee » Fri Dec 04, 2009 11:08 am
OK,
I must have misread the part about the small brushes, and am now on my way to the ER to get my right little finger removed from my left ear (hopefully without having to remove to much of the ear).
Where did I go wrong?
Man it is tough to type this way.
:mrgreen:
RickBarbee
Postby Dave Beeler » Fri Dec 04, 2009 9:28 pm
Rick, ya gotta be kiddin man, are you serious?
Dave Beeler
Postby Headhunter » Thu Feb 25, 2016 11:17 am
just a couple of things to add: 1) I use a surgical glove one finger at a time. just pull the latex tight over your glue finger, you get at least 5 uses from one glove. 2) titebond makes the best thin CA for wood I've used, some are a little like thin syrup. you want the glue to soak in a little, the strength the surface wood fibers get when they absorb the water thin CA is amazing.
Jerry Carr
Headhunter
Users browsing this forum: No registered users and 8 guests
